一、準備:
1、檢查投影位開關是否處于關斷位置;
2、檢查開關電源、投影儀電路是否處于接通狀態;
二、操作:
1、啟動機臺總電源;
2、開啟計算機;
3、開啟投影儀操作軟件:
4、將待測產品放到測量夾身上,然后將夾具輕放到投影儀操作平臺上,靠在固定夾具上
5、依據產品的尺寸及規格,進行投影、投影結束后可以在CAD軟件進行測量,最后記
錄相關的數據并進行下一輪測量。
三、
1、關閉操作軟件程序(先將必要的檔案存盤)
2、關閉計算機;
3、關閉機臺;
4、若無后續測試,蓋上防塵罩。
(二)、 注意事項
1、出于安全和對測量的精度影響,請勿直接接觸機器內部器件以及表面光源中間部分的鏡頭;
2、定期擦拭載物臺及周圍部分,避免灰塵進入機臺內部以致影響機臺精度;
3、本儀器為高精度儀器,非專業人員嚴禁操作;
4、切勿在載物臺上擺放超過承重的對象,以免損壞機臺;
5、在日常操作過程中應注意防止載物臺面的劃傷;
6、請勿在計算機上擅自安裝或卸載軟件,以免導致系統崩潰或操作軟件無法正常運行;
7、定期對儀器加潤滑油以保持儀器的精度;
8、嚴禁人手扶或靠在機臺上,以免機臺失去精度。
英斯特力儀器是一家集研發、生產及銷售于一體的 影像測量儀,拉力試驗機, 硬度計 ,探傷儀, 粗糙度儀, 測厚儀, 金相設備廠家, 致力于為客戶提供更好的檢測儀器。
I. Preparation:
1. Check whether the projection switch is in the off position;
2. Check whether the switching power supply and projector circuit are switched on;
Two, operation:
1. Start the total power supply of the machine;
2. Turn on the computer;
3. Open the projector operating software:
4, put the product to be tested on the measuring clamp, and then put the fixture lightly on the projector operating platform, leaning on the fixed fixture
5, according to the size and specifications of the product, projection, after the end of the projection can be measured in CAD software, and finally recorded
Record the relevant data and conduct the next round of measurement.
Three,
1. Close the operating software program (save the necessary files first)
2. Turn off the computer;
3. Close the machine;
4, if there is no follow-up test, cover the dust cover.
(2) Matters needing attention
1. For the sake of safety and the impact on the measurement accuracy, do not directly contact the lens of the internal components of the machine and the middle part of the surface light source;
2. Wipe the loading platform and the surrounding parts regularly to avoid dust entering the machine so as to affect the accuracy of the machine;
3, the instrument is a high-precision instrument, non-professionals are strictly prohibited to operate;
4. Do not place more than load-bearing objects on the loading platform, so as not to damage the machine;
5, in the daily operation process should pay attention to prevent scratches on the loading table;
6. Do not install or uninstall software on the computer without authorization, otherwise the system will crash or the operating software cannot run normally;
7, regularly add lubricating oil to the instrument to maintain the accuracy of the instrument;
8. It is strictly forbidden to hold or lean on the machine so as not to lose accuracy.
