硬度計的分類和使用,以及維氏硬度計的操作流程
發布時間:2022-05-04 10:16:57人氣:
硬度計的分類
  一、按材質分類
  金屬硬度計、橡膠硬度計、石材硬度計、水果硬度計
  2.按名稱分類
  1) 洛氏硬度計 HR 表面洛氏硬度計 HR(15.30.45)(N,T)
  2) 維氏硬度計HV
  3)里氏硬度計HL
  4) 布氏硬度計HB(S)
  5) 肖氏硬度計HS
  6)邵氏硬度計HA
  7)韋氏硬度計HW
  8)巴氏硬度計,一個單位相當于壓痕深度0.0076mm
  3、按類型分類
  便攜式硬度計(便攜式硬度計)、臺式硬度計、多功能硬度計、超聲波硬度計、目測硬度計
  4、按示值分類顯示
  數顯硬度計、指針顯示硬度計、讀數值校驗顯示硬度計
硬度計適用場合
  洛氏硬度計:用于測量鑄鐵等工件的洛氏硬度值
  維氏硬度計:薄工件的維氏硬度值測量
  布氏硬度計:用于測量硬度較高的工件的布氏硬度值
  肖氏硬度計:用于測量橡膠制品的肖氏硬度值
  韋氏硬度計:用于測量鋁合金產品的韋氏硬度值
  巴氏硬度計:用于測量玻璃鋼制品的巴氏硬度值
  萬能硬度計:用于各種硬度標度下的硬度值測量
  顯微硬度計:維氏硬度計的一種,用于測量極薄工件的維氏硬度
  肖氏硬度計:用于測定黑色金屬和有色金屬的肖氏硬度值
硬度計的分類和使用,以及維氏硬度計的操作流程(圖1)
Classification of durometer
One, according to the material classification
Metal hardness tester, rubber hardness tester, stone hardness tester, fruit hardness tester
2. Classify by name
1) Rockwell Hardness Tester HR(15.30.45)(N,T)
2) Vickers Hardness tester HV
3) Richter hardness tester HL
4) Brinell Hardness Tester HB(S)
5) Shore hardness tester HS
6) Shaw Hardness tester HA
7) Vickers Hardness tester HW
8) Barclay hardness tester, one unit is equivalent to indentation depth of 0.0076mm
3. Classification by type
Portable hardness tester (portable hardness tester), desktop hardness tester, multi-function hardness tester, ultrasonic hardness tester, visual hardness tester
4, according to the value of classification display
Digital display hardness tester, pointer display hardness tester, reading value check display hardness tester
Hardness tester applicable occasions
Rockwell hardness tester: used to measure the rockwell hardness of cast iron and other workpiece
Vickers hardness tester: Measuring vickers hardness of thin workpieces
Brinell hardness tester: used to measure the brinell hardness value of the workpiece with high hardness
Shore hardness tester: used to measure the shore hardness of rubber products
Vickers hardness tester: used to measure the vickers hardness value of aluminum alloy products
Barb hardness tester: used to measure the barb hardness of FRP products
Universal hardness tester: used for measuring hardness values under various hardness scales
Microhardness tester: A type of Vickers hardness tester used to measure the vickers hardness of very thin workpieces
Shore hardness tester: used to measure the shore hardness of ferrous and non-ferrous metals
